John2004
- Mar 29, 2004
- 237
I ran across this thing called the "lever paradox" on page 19 of the book "1800 Mechanical Movements" by Gardner D. Hiscox. I think the same lever mechanism is shown in Gardner's other books on mechanical movements, some of which can be downloaded free via google's book search function.
I have included three links below showing pictures of the lever mechanism in three different positions, i.e., unloaded, loaded on one side only, and balanced with loads at each end.
The paradox here is that the lever will always balance as long as equal weights are placed on each side, regardless of the distance of the weights from the center lever pivot point.
I had a couple of notions as to what may be going on here, but I'm not 100% sure. What is actually going on & why does this lever always balance even when equal weights are placed at different distances from the lever pivot point ?
John
John
