Instnapp
Industrial
- Oct 9, 2013
- 13
Hi All,
For a 15,000 PSI Chart recorder, at what percentage of the chart should be the safe test pressure prior to getting a recorder with a higher range.
For example, I want to test an item at 13000 PSI,can I use the 15000 PSI recorder or will I need to get one with a higher static range?
Thanks and Appreciate your feedback.
