Terramodel-export in dwg
Geotechnical
Jun 27, 2005
1
plese if everyone can help me about exporting points from terramodel vers.10.3 to dwg?
with usual export manager i can get dwg, but in one layer, i can't get points, points number and elevation in diferent layer.
thanks
damir
Damir,
When exporting DWG file, under the Point Options, select "Export point as block with attributes". I usually leave the "Center elevation around point marker" off, and use a text height of 0.1. Thie will give you a layer for Descriptions,Elevations and Point Number as well as your existing point layer.
Hope this helps.
Bernie
