mflam
- Apr 12, 2005
- 30
Should an above ground temporary water main be considered a potential source of contamination?
Should it be isolated from the permanent system with backflow preventers?
What if it is looped into the permanent system at two points?
The loop configuration makes the system more robust and supplements fire flows but, of course, backflow prevention would at the points of connection would prevent the main from acting as a loop.
