Temperature rating of SA 516 Gr 60 3
Moossii
Chemical
Dec 27, 2017
4
Where should I look to find out the minimum temperature rating of SA 516 Gr 60?
Yes sir. The ASTM equivalent is A 516 Gr 60
If you mean the lowest permitted temperature that will depend on material thickness and heat treatment in ASME Section VIII, Div 1.
See UCS-66. Look at the curves in the figure therein.
