Target Drone Mil-specs
Wittenborn
Aerospace
Jun 5, 2003
151
I am looking for military specifications for the design of target drones. I have been having a problem tracking down any doccuments on this topic.
If anyone has any references to the design standards for UAV's, I'd be most appreciative.
Grant Wittenborn
Aerospace Engineer
Have you tried this site for online MIL specs?
I searched for target drone and came up with 2 results. You should also try searching for UAV and Unmanned Aerial Vehicle.
--Scott
Thanks, Scott
I have not tried this source, but I looked at the DTIC.mil account and everything I found is either from 1950 or restricted. I just signed up for an account.
I appreciate your help!
Grant Wittenborn
Aerospace Engineer
I can't see that there would be a MIL-SPEC for a gereric UAV. MIL-SPECS are to ensure conformity in materials, performance, spares etc and except for a spec covering some complete assemblies they are for parts and processes. You won't get a MIL-SPEC for an aircraft. There will be a bucket full of specs you might choose to include in the design to make sure you get the same bits every time you order them.
BrianR,
The mil-spec I was looking for is a generic set of specs for an aerial target. MIL-T-18232 Rev B is the spec on this.
This report is also the "bucket" you refer to, as it contains a ton of other more specific specs for individual components, parts and assemblies.
I did get the application to the ASSIST website, which is where I found this spec.
Grant Wittenborn
Aerospace Engineer
