Tap into a blind hole
nornrich
194
All,
Is there an option on the hole wizard to drill and tap for machined flat bottomed hole?
Rich.....[viking2]
Richard Nornhold, PE
Use the Show custom sizing option in the Hole Specifications section to change the drill angle to 180°.
The drilling and tapping depths can be controlled in the End Condition section.
Ditto to CBL's suggestion.
Best regards,
Chris Gervais
Application Engineer
CSWP, CSWST
Do as CBL suggested and if you need it over and over, add it to hole favorites.
Deepak Gupta
SW2009 SP3.0
SW2007 SP5.0
MathCAD 14.0
