Table driven kinematics 1
wrightti
Automotive
Jul 5, 2009
42
Does anyone know of a method to drive a kinematic assembly from a lookup table of values instead of with laws. I have a mechanism with 3 commands and I want to simulate about 1000 discrete points. I have the command values already in excel, and it would be a pain to have to draw out a law for each command.
Any ideas?
Tim
When you say it'd be a pain to draw out the law for each command, I assume you mean to do so in Sketcher. What you should be able to do is convert your excel data points to a TXT file with the following format (see attached from Catia V5 help) and import that to your mechanism - double click the first command, click 'import' and find your formatted TXT file.
If this helps, great. If this is what you were saying that it'd be a pain to do, then I don't know another method to make it easier - sorry!
By the way, the full help file is available at: Catia V5 help dir > DMU Kinematic Simulator > Advanced Tasks > Mechanism Design > Defining Laws in a V5 Mechanism > Defining Laws using a 2D Curve
Kevin Irrer
Powertrain Engineer
IAV Inc.
 http://files.engineering.com/getfile.aspx?folder=d66dfc6e-211c-4331-a692-d27ab36faae5&file=importfile_01.gif
Hi Kevin,
Thanks for that info. I actually did find this help file today in the end. I was avoiding the section called "Defining Laws using a 2D Curve" because I wanted to do it with a text file!
I have trialled the method with a basic input and it works as I want. I'm generating the text file with about 1000 points automatically from excel so its infinitely easier to make than drawing each law by hand.
cheers again
Tim
Tim. have you tried using a Design Table to drive the kinematic parameters?
Hi Jack,
I havent tried this. Is there anything in the help documentation about this?
In the end I took the points from a text file and imported them as Kevin suggested. It worked well.
Id be interested in hearing how the design table metehod works.
Tim
Tim,
First of all, I'm assuming you have a kinematic mechanism with multiple inputs. And you want a table of those input values to plug into the mechanism and have it move to that into that particular configuration. Right?
The basic steps for doing this with a design table are:
1. create a parameter for each input
2. link the parameters the the appropriate assembly constraint
3. make a design table (and spreadsheet) based on the parameters
4. add additionsl colums with various values
5. choose a design table configuration to apply to your assembly and update the assembly.
(as I'm writing these steps, I realized that you really don't need to use the DMU Kinematic workbench for this. As long as your mechanism assembly is fully constrained, the design table will drive the mechanism.
