Symbolic objects
musilj
16
Hi all,
How can I create a matrix of symbolic objects like
A=[a1,a2,a3,a4.........a60] using possibly an index
such as i=1:60 if possible .
Again is it possible to mix symbolic objects and numeric decimals in one matrix, such as
A=[a1,a2,a3,4,5,6,a4....]
cheers
musilj
A=[sym('a1'),sym('a2'),sym('a3'),4,5,6,sym('a4')....]
Code:
for i=1:60
A(i)=sym(strcat('a',num2str(i)))
end
Code:
hi electricpete
A quick paste into matlab of your code with the index resulted in the following error.
??? The following error occurred converting from sym to double:
Error using ==> sym.double at 25
DOUBLE cannot convert the input expression into a double array.
If the input expression contains a symbolic variable, use the VPA function instead.
Error in ==> trial at 5
A(i)=sym(strcat('a',num2str(i)));
cheers
Hmmm. Works for me. Try executing clear before you run it.
Otherwise there must be a difference in the behavior of matlab on our machines. I have an old version Matlab 5.2
