SBaugh
- Mar 6, 2001
- 6,686
53.03 is the driver you are suppose to use with the actual Quadro 500 FX. It is that driver that has been approved by SW for that card. Since your hacking the card with drivers, then I would say that's why your Realview isn't available. It's because 1 that card isn't approved and 2 those drivers are also not approved. I would venture to say your SOL, unless you go and spend about $225 for the card. Small price to pay if you want to have and use realview, plus stable drivers.
Plus another benefit of the card, You VAR can't blame the video card for the problem as often.
Scott Baugh, CSWP![[pc2] [pc2] [pc2]](/data/assets/smilies/pc2.gif)
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
Scott Baugh, CSWP
