KristjanGerhard
- Apr 16, 2015
- 8
Hi
I'm in the preliminary steps of designing a cooling system for a hydroelectric power plant refurbishment. I'm looking at numerous options in regards to arrangement of the cooling system.
Currently I'm looking into placing a heat exchanger in the tailwater pit of the turbine. A custom designed pipe coil heat exchanger would be viable but rather costly. In light of this I'm looking for manufacturers that can supply off the shelf submersible heat exchangers capable of withstanding this high flow environment.
Any suggestions?
KG
Any suggestions?
KG
