Structural Simulation - No results are found
MarianaM43
Hi, I've been trying to run a structural simulation (S101) using NX Nastran 9.0, a simple one, but I can't get a result and don't know what to do to fix the error. Usually appears No results are found with "error occurred in results collection nx", but I also got Result file in wrong format.
The message that appears at the .f06 file is:
*** USER WARNING MESSAGE 2354 (GPFDR)
MODULE IS UNABLE TO CONTINUE AND HAS BEEN TERMINATED DUE TO ERROR MESSAGE PRINTED ABOVE OR BELOW THIS MESSAGE.
THIS ERROR OCCURRED IN CODE WHERE THE VARIABLE -NERROR- WAS SET = -99
*** SYSTEM WARNING MESSAGE 3001 (GPFDR)
THE INPUT DATA BLOCK NAMED UG AT POSITION 2 DOES NOT EXIST.
USER INFORMATION: THIS ERROR IS CAUSED BY ONE OF THE FOLLOWING:
1. THE DATA BLOCK WAS NEVER CREATED.
2. THE DATA BLOCK WAS DELETED.
3. THE DATA BLOCK IS SPECIFIED ON A TYPE STATEMENT IN THE CURRENT SUBDMAP OR A HIGHER SUBDMAP
BUT THE CURRENT QUALIFIER VALUES DO NOT MATCH
THE QUALIFIER VALUES OF THE DATA BLOCK(S) ON THE DATABASE.
USER ACTION: 1. IF YOU ARE EXECUTING A SIEMENS PLM SOFTWARE SUPPLIED SOLUTION SEQUENCE AND NOT USING THE
ALTER EXECUTIVE CONTROL STATEMENT, THEN CHECK FOR BULK DATA AND/OR CASE CONTROL INPUT
ERRORS. IF NO ERRORS CAN BE FOUND, THEN CONTACT SIEMENS PLM SOFTWARE CUSTOMER SUPPORT.
2. IF YOU ARE EXECUTING A DMAP PROGRAM NOT SUPPLIED BY SIEMENS PLM SOFTWARE, THEN FOR DEBUGGING
PURPOSES INSERT STATEMENT DIAGON(20) BEFORE THE MODULE SHOWN ABOVE.
PROGRAMMER INFORMATION: THE FIST NUMBER IS 102 AND SUBROUTINE IS GPFRBI
I've searched to change some configurations, but got nowhre.
 https://files.engineering.com/getfile.aspx?folder=c2cf38fc-4fdf-44b9-a490-40fc3a5a9677&file=base_elo1-2-simplificado_sim1-solution7.f06
