Twoballcane
- Jan 17, 2006
- 951
Hello All,
Let’s assume that an angle iron’s sides are being squeezed towards each other and pivoting at the elbow. On the stress plot you can see the stresses on the outside and inside part of the elbow. Now, some time in the past I do remember reading an article about stress concentration in FEAs. That the nodes on the curve, because of the math, will calculate higher stress than what might be really happening, it also said that to get a good estimate of “true” stress to read the surrounding nodes near the curve. So in the end, the highest stress in the legend is not what you want to take as max, but the next level down from the top.
Can somebody tell me if I’m imaging this, because I can not find any info on this on the web?
Also, I use Pro Mechanica if that helps.
Tobalcane
"If you avoid failure, you also avoid success."
Tobalcane
