Straightness Tolerance Box 1
ImnotfromMars
48
Today I saw a tolerance box for straightness which had a tolerance of .005/1 RFS.
I guess it means the part must be straight within .005 per inch. Does anyone know where in the ASME Y14.5 it allows this? I was unable to find it.
See paragraph 5.4.1.3 of the standard ASME Y14.5-2009. Also see Fig. 5-4, which shows that "per-unit" idea as a subset of an overall straightness tolerance (although the overall straightness isn't necessarily required).
John-Paul Belanger
Geometric Learning Systems
Just a minor point, but that straightness tolerance likely applies to a specific surface or feature and not the entire part.
This type of unit restriction can also be used with flatness. I've never seen it by itself -- always as a composite control with an overall tolerance above and a smaller unit tolerance below.
