Stair well pressurization
Dave D
5
I know there's a formula to calculate pressurization fan for a stair well, but this formula requires a lot of detail information that I don't have e.g. # of doors, leakage area, walls and ceiling surfaces, etc.
Is there a simpler equation that can be used with only cu-ft of the the space?
Thank you
Succinctly put Willard!
I concur.
As an aside, I would recommend against sizing systems based on insufficient data. If you're doing budgetary analysis, make some assumptions and do the calculation or use engineering judgement based on past projects.
Get your hands on Australian Standard 1668.1
It gives a min m/s velocity across open doors and how many doors deemed open and depending on type of pressurisation system
