drawoh
- Oct 1, 2002
- 8,958
I am preparing a drawing of a stainless steel sheet test piece to test the set up of a spot welder. Our customer has called up a McMaster Carr part number that points to Stainless Steel 304 hardened to Rc40. Is (work) hardness a factor in spot welding? I assume we will try to rip this thing apart to test the spot weld. Will it be hard in the heat affected zone (HAZ)?
Basically, does the hardness matter, or can I just write STAINLESS STEEL 304 on the drawing?
JHG
JHG
