SPLIT MUFF COUPLING
Adrian77
Marine/Ocean
Sep 4, 2003
31
Hello All,
I am calculating a split muff coupling for a round shaft fitted with 3 bolts on each side. I need to calculate the pressure on the shaft surface in order to calculate the maximum torque to be transmitted (with a fricton coeffcient). I know the bolt load, but I am not sure about the resulting surface pressure. Can somebody provide any advice ?
Thanks in advance.
Best regards,
Force under a bolt is about (F = T / .21 * d)
As for fricton coeffcient I generial use 0.1 for steel on Steel.
I holpe that this helps
Chris
"In this house, we obey the laws of thermodynamics." Homer Simpson
