Splines in Autocad
arun17
44
Hi friends,
I want to draw a spline in Autocad.I am having the coordinates of the points( approx. 1000 points), through which spline is to be drawn, in a data file. I want to read the coordinates from the data file and draw the spline. How we can do it using a simple lisp routine or VBA routine. Obviously I would not like to do it manually because I want to compare the splines drawn for various data files containing same amount of data.
Any suggestions?
Thanks.
"Knowledge is power"
I would export the coords into excel, save as a script and "import" it back (a lot of work).
Maybe Landcad can more...?
Lothar
Win NT4.0(SP6),2000(SP3)
AC 2000i(SP2), ADT 3.0(SP3),
AC 2002, ADT 3.3,
AC 2004, ADT 2004
My data file is a tab delimited file generated by some other software. I have already read the file in excel. How to get this data in Autocad from excel?
what version of acad, any other add-on applications?
if not, then post e-mail, i will send you mine. then send file, i will generate the points and pline and return in dwg format, you can then manipulate as needed
by the way, i will be using acad + eagle point for this.
if you do this often, then a good civil package will help.
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
I don't know if you want a spline or line but I'll tell you how to do either from excel.
first open your excel and autocad.
now I am going to assume your data is in 2 colums such as bellow.
A B C etc
1 X Y
2 1 1
3 5 2
etc
1001 27 35
You need to make another colum with the following command
=A2&","&B2
and copy it down the column.
A B C etc
1 X Y
2 1 1 1,1
3 5 2 5,2
etc
1001 27 35 27,35
Now in the spot c1 in the diagram You can write _line
and hilight c1 through c1002 hit control C to copy and then in Autocad hit control V at the command line to paste.
To spline put in _spline instead of _line in cell c1 and then you need to put some points for the start and stoping tangents in cells c 1003 and c1004.
You can also start the comand (_line) and just paste in the coordinates.
@arun17: thread555-52987 "spline" in the first line
if You want,you mail the *.xls to Kramer24@freenet.de
I would have a look...
Lothar
AC 2002, ADT 3.3,
AC 2004, ADT 2004
Thanks exit & Facilitiescad. I tried the method suggested by Facilitiescad and it worked nicely.However I had written a VBA routine also which read my data file and plots the spline using Addspline method.
Problem is solved!!!!!!!!!!!
