special characters for triangle in journal (NXOpen API)
lklo
Industrial
Nov 24, 2010
226
hi -
Does someone here know, if it is possible to use the unicode character: U+2206 for "Triangle or Increment" in a journal.
I'm writing some text in a tabular note with my journal - but I can't figure out, how to let the journal handle these special characters.
As an example I'm able to use Chr(34) as a quoate....But should it be possible to do something like this, also with a triangle or increment char like this: ∆
link to Unicode Character Search: Link
regards lklo
Use ChrW()
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
   Sub Main (ByVal args() As String)
       Dim theSession As Session = Session.GetSession()
       Dim triangle As String = ChrW(8710) ''UTF8 32 Decimal
       msgbox(triangle)
    End Sub
End Module
hi Petulf -
thank you so much for your reply..
1.When output the string to a msgbox , it works perfectly.
2.But in my case I need the value in a tabNote and when I try to use the string as input string to the cell, the value from string is just treated as an hash: #
3. I also tried to output to NX listingwindow - in this case an error is raised...
please see attached zip file - containing 3 screenshots - one from each scenario....
Maybe you have some comment's on this....
In advance - thank you...
regards lklo
 http://files.engineering.com/getfile.aspx?folder=9295e8fe-a887-43b0-ac39-7661e789ee3d&file=3pics.zip
Unrecognized character for the font used maybe?
Tried using?
Code:
Dim delta as String = "∆"
The listingwindow cannot handle all UTF-8 Characters, this should according to gtac be fixed in NX10.
Thought using Dim triangle As String = ChrW(8710) ''UTF8 32 Decimal works for creating notes in drafting mode without causing exceptions.
Hi again
thanks for your input...
I tried these in NX 8.5 - but still without succeeding....
Though I found out that a direct input of the triangle is possible....see attachment
But I need to be able to do it programmatically....
I will give it a try in NX 11....
lklo
 http://files.engineering.com/getfile.aspx?folder=7f9de7b9-fcea-466f-81cf-fdd88f34e820&file=triangle_direct_input_works.JPG
