Spain and Portugal power grid collapse
LittleInch
Petroleum
Mar 27, 2013
22,565
Widely reported, the Spanish and Portuguese electricity supply collapsed 28th April after it lost 15GW of supply (about half of its consumption) in 5 seconds. Not surprisingly the interconnected to France the European grid tripped and the grid collapsed.
This M is nearly un heard of and lights just how much we all rely on Grid power. Basically nothing worked. No mobile coverage, precious little Internet, no ATM or even if you had cash the tills didn't work. Trains stuck in tunnels or out in the middle of no where and traffic gridlock.
Some standby power, but limited and also limited in duration for hospitals, airports etc.
If there are some grid sparkies out there, please do some digging and see why this happened? No one so far as I can see can say why supposed high vibrations or fluctuations in the HVgrid caused such a dramatic loss of supply.
Seems to be slowly recovering today, but I can imagine bringing an entire country back on line is not straightforward.
This what the head of the Spamish Grid said. Anyone able to interpret this?
" Sánchez said that the power cut originated at 12.33pm, when, for five seconds, 15 gigawatts of the energy that was being produced – equivalent to 60% of all the energy that was being used – suddenly disappeared.
“That’s something that has never happened before,” he added. “What prompted this sudden disappearance of the supply is something that the experts still haven’t been able to determine. But they will … All potential causes are being analysed and no hypothesis or possibility is being ruled out.”
Sánchez thanked France and Morocco for sending additional electricity to Spain, and said the current shortfall would be eased using gas and hydroelectric power.
The Portuguese operator, REN, said the outage was caused by a “rare atmospheric phenomenon”, with extreme temperature variations in Spain causing “anomalous oscillations” in very high-voltage lines.
REN said the phenomenon, known as “induced atmospheric vibration”, caused “synchronisation failures between the electrical systems, leading to successive disturbances across the interconnected European network”. "
Immediately before the failure, the majority of power on the grid was inverter sourced, not rotating. I have heard talk of motorizing retired generator units in order to improve inertia of heavily solar/battery supplied grids.
I imagine it will be a long while before we have a conclusive analysis.
It's outside my realm but if I had to guess I'd say it will have to do with the "ride through performance" of the inverters.
Perhaps incorrect (or insufficient) Inverter settings.
Sometimes I see them. Sometimes no. Like now.
Oh. Thanks. Pages.
What a nice feature. You can ignore all previous threads and just type the same answer someone already did on page 1.
I tried to get them to give us the option of 20, 50 or 100 posts per page, but that fell on deaf ears....
There does seem to be quite a bit of concern about the high level of solar and wind power and at midday that would be peak solar.
Mr 44 - does that website on post 17 give a key to what the percent of different generation was at the time of collapse?
So maybe settings need to be adjusted and some different circuit breakers installed to prevent total collapse. Electricity stuff happens so fast compared to fluid transport.
