SPACEBALL
kwkmts
25
How do I get Solidworks to see my spaceball?
Make sure your webcam have the Solidworks approved drivers or it will not work.
SW07 SP2.0
Flores
Nice. ..
What version of spaceball and drivers do you have? Does Windows appear to see it in the devices area? Is it USB, serial, ? connection?
Jeff Mowry
Reason trumps all. And awe transcends reason.
First, assuming you have loaded the driver, you need to make sure it's running. Start/Programs/3Dconnexion/3Dconnexion3DXware/Start Driver
Once the driver is running (there should be an icon in your tool tray) make sure you have the add-in activated in SolidWorks.
Also, if you have the 5000 USB, you might need to download the 3DxOffice Plug-in. On the page that smcadman gave you the link for, select your product, then 'Archive (Legacy Software), then 3DxOffice Plug-in.
Hope this helps.
Jeff Mirisola, CSWP
CAD Administrator
SW '07 SP2.0, Dell M90, Intel 2 Duo Core, 2GB RAM, nVidia 2500M
install/reinstall driver after solidworks is installed.
The driver adds the add-ins as it sees programs that can use it.
Is there a Spaceball 5000 USB driver for Windows XP Pro x64 available? I couldn't find any mention at With the x32 driver, my Spaceball would work in SW but wouldn't in almost any other application.
