RWW0002
- Jun 10, 2011
- 387
I know there have been several posts concerning the reduction in Southern Pine design values over the past year, but varying agencies and sources seem to be at odds on whether NDS Supplement 13 (with an effective date of June 1 2013) has already taken affect for all new IBC-based design or whether local jurisdictions must adopt the change.
The following from Southern Pine Inspection Bureau implies that enforcement varies by jurisdiction (see Q11).
This "non-mandatory unless approved" sentiment is echoed in several other sources, but I was under the understanding that since ALSC (American Lumber Standards Committee)approved the change per IBC referenced ASLS PS 20, the values take affect June 1, 2013 and should be used for design without specific jurisdictional approval. (Sorry for all the acronyms)
Bottom line, if the local jurisdiction (under IBC 2006 or 2009) has not mandated the use of the new design values and has not approved any amendment to the prescriptive design sections of the IBC, do the updated design values have to be used?
