ajf46
- Oct 6, 2010
- 2
The plate shown in the attachment has a bearing load of 12500N on the bottom larger hole, the top two holes have fixed hinge geometry.
The min FOS result is 1.34, just at the bearing load point. All around this point there is material where the FOS is over 5.
Would you consider the FOS on this part to be 1.34? or higher because that load is compressive at that point and is supported all around?
It is a 10mm plate and the distance between the 2 smaller holes is 195mm
