chumet1
- Feb 6, 2013
- 40
attached is a coupling and shaft layout. the coupling with initial ID of 80mm was bored out to 100mm to suit the shaft diameter of 100mm. the shaft was inserted into the coupling up to 140mm to allow for sprocket alignment at the other end of the shaft. my question is: is there a standard minimum amount of coupling hub material labelled Y on the diagram that is required to be left for an effectively strong coupling-shaft fit, with respect to shaft diameter. and also the standard minimum contact length between shaft and coupling with respect to shaft diameter...
thank you
thank you
