ohmrun
- Aug 1, 2001
- 20
A 12 watt soldering iron has a tip that weighs about 2 grams. I need some help in determining how hot does the tip get? The Formula Q=M x Cp x dT seems to produce a dT of 85,370 when Cp is .109BTU/(lb x F)(assuming nickel steel material). This seems way out in left field. Any help is appreciated.
