lewtam
- Jul 4, 2003
- 219
Hi everybody - I need 2 filter housings for our dehydration system in a mid stream natural gas conditioning plant and am having trouble finding a manufacturer willing to offer. Below is a summary of what I have been asking for, is there something I am specifying that is a hassle/deal breaker or is there anything that shows me up as a time waster?
Design Code: ASME Sec. VIII Div.1
Fluid Service: Tri ethylene glycol (TEG) – Specific Gravity 1.125
Glycol Flowrate: 1450 kg/hr (~approx 430 Gal/hr)
Temperature at proposed filter location: Operating 45C (Design max 70C, design min -29C)
Pressure class: ASME 900# (Operating pressure 9500kPa, max system design pressure 13900kPa)
Material: Compliant with manufacturer design to ASME VIII Div 1, if carbon steel or low alloy steel is selected, a 3mm corrosion allowance must be included. If Stainless Steel /Corrossion Resistant Alloy is selected, no corrosion allowance required.
Process Connection type: Inlet/Outlet 1½” ASME B16.5 RF Flange
Additional Ports: ¼” NPT drain, ¼”NPT Differential Pressure Ports
Filter Element: 10-25 micron
O-Ring Material (if required): Viton
Number required: 2 x filter assemblys + 2 spare filter elements
Delivery Terms: FCA US major city (packaged for export to Australia)
LewTam Inc.
If you type 'Google' into Google.....you can....break the internet.
LewTam Inc.
