Slab with openings
designs
I am interested in finding literature on design of reinf. concrete slabs with large openings.
I do not have litrature on it but I would model with solid and beam elements. <p>Roni Plachta<br><a href=mailto:Roni@AnalysisPros.com>Roni@AnalysisPros.com</a><br><a href= - Finite Element Analysis Services</a><br>Product defects and failure analysis. Structural, thermal and flow testing and simulation. Expert witness testimony. Accident investigation and reconstruction. Experience in Aerospace, Appliances, Automotive, Civil, Marine, Medical, Power, Sports, Tooling
Try the German book &quot;Platten&quot; by Stiglat and Wippel.
Probably you can use any of the plastic approach to design your slabs with cut-outs. <p>azmi ibrahim<br><a href=mailto:azmi@civil.engr.itm.edu.my>azmi@civil.engr.itm.edu.my</a><br><a href= > </a><br>I'm always keen to learn more to advance<br>
myself in areas that I'm interested in.
Prueba usar un software que se llama SAFE.
I think Jose is recommending SAFE from CSI Berkeley.
I would suggest using any FEA software like SAFE or RISA3D. Whatever means you use, be sure to accurately account for the effect of openings near column supports (i.e. reduced punching shear capacity). Since design for punching shear typically assumes that the loads come in from all directions, having an opening within the vicinity of a support will change the load path and thus change the shear behavior over that support.
