TTomaz
- Jan 17, 2020
- 10
Hi there,
ACI 318-19 presentes throughout its new version a size effect factor, which directly reduces shear strength in thick slabs, for example.
In my case, I do have really thick slab subjected to high shear load.
The shear concrete strength (Vc) of my 150 cm (59'') slab 40 MPa (6000 psi) is only 350 kN/m due to a 0,58 size effect factor, which didn't exist before, which is a rather low considering the ultimate loads (around 1000 kN). Flexural reinforcement rate is the minimum (0,18% * Ag).
How have been your experiences with the new code with this factor?
