VanNuysDave
Geotechnical
- Mar 5, 2003
- 9
As stability analysis software becomes more sophisticated, we can now realistically incorporate stabilization mitigation methods into the slopes - specifcally - shear pins.
Typicaly we find that shear pins are either driven steel piles or CIP bored piles with either a cage or a beam and CIP's are 2-6 feet diameter. The range of shear forces we see that are used for the steel and concrete section are 11,000 to 75,000 lbs per foot of pile out of plane spacing.
My question is - what is an appropriate shear force to be used for a preliminary shear pin design assuming a CIP aproach with a reinforcing cage ? There are so many combinations that can be used by the structural engineer after we are finished with our stability analyses - so are we being too liberal or too conservative for the preliminary analyses ?
