Setting the PDF file export name - Possible?
RobLN
152
Hello
I have a question regarding the export of the PDF in NX (8.5)
Is it possible to set the filename of the PDF to be something else i.e:
BASE012345_A_PDF --> BASE012345_A_RELEASED
At present the default is _PDF.
Additionally, would it be possible to get NX to automatically append the 2D file sheet name in place of the _PDF everytime you do an export...?
Thanks for having a look - all responses greatfully received.
Rob.
Solid Edge; I-Deas 7 to 12; NX4 to NX8.5 / TeamCenter 9.1 & Ansys 14.5
As far as I'm aware, the naming for PDFs is in the plot settings in Customer Defaults (see attached image).
However, I'm not sure that applies when NX is used with TC.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Hello Cowski - It will reside within TC item once exported.
