Self weight in Ansys
sudhakarn
Automotive
Apr 1, 2013
506
Hi folks,
I have been exploring both Ansys and Staadpro. I am just curious that why is it that self weight is considered only in staadpro and not in Ansys.
Really wonderful to be part of this community.
Ansys will consider self weight if you tell it to.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Hi Rick,
Thanks for your reply. But I would like to know what difference it makes? Why don't we consider self weight in mechanical designs? Why do we considered self weight only in case of structures in civil engineering?
Would be greatful if I get answers to the above queries.
Thank you.
Who says "we" don't consider self weight in mechanical designs? If its appropriate to my analysis, I include self weight. if its not, I dont. My guess is the rest of we do the same.
Ansys doesn't include self weight by default because it is a very general purpose program and geometry can be imported with random orientation. Im guessing that if it decided that global Y was up, and a part designed with global X as up was imported, an improper load would be applied that might not be obvious to newbie or casual users. I think their approach is they supply the model, but the user builds the model and runs the analysis. In any event, its easy to do with the ACEL command in MAPDL, and Workbench has a gravity load (which requires you to pick the up direction), so really its no big deal. I have no experience with Staadpro, but it looks like a dedicated civil engineering type structural package, so perhaps in that context it makes sense to include self weight by default. But the reality is that gravity is largely irrelevant to the analysis of all kinds of stuff. Is it more correct to include gravity? Yup. Is it always relevant? Nope. When you add in discretization error, variable material properties, etc, the effect of gravity gets lost in the noise.
Rick Fischer
Principal Engineer
Hi Rick,
Thanks a lot for your detailed insights. Will explore further and revert.
Cheers!!
I want to specify that gravity might not be the design load for mechanical purposes, but in CW it can be more than relevant. But yes, the gravity is not added by default because it is a general purpose FE software, so if you want for example to consider a different gravity value, or a more adapted direction (who said that gravity is -Z in all models?), you can do it.
More, it should reinforce the conscience about Ansys and similar software, where you control nearly everything. Even gravity. So you must have clear in your mind what you're doing.
