selection
pk805
New member
Mar 23, 2009
8
I'm an Ansys novice and I'm working on someone else'input deck. I've come accross the following area selection code:
ASEL,S,LOC,X,0,9.5,
What does this actually mean? Ansys Help says the Loc command selects a 'hot spot'. What exactly is a hot spot? Is teh hot spot a point on the area?
Cheers,
PK
This command selects any geometrical area along the X-plane between 0 and 9.5 units in the model.
See faq569-1083 for details on how to make best use of Eng-Tips.com
Cheers for the reply, but I'm still a bit confised.
When you say x plane is that xy plane or xz plane? And also is that according to teh work plane or the coordinate system?
The only reason I ask is that the command seems to select an area which does not lie at x=9.5 in the coordinate system I have used. I checked this by listing keypoints on the area and checking coordinates. Not sure if the fact cyclindrical coordinates changes things either...
Could you shed some more light? Thanks
The command will locate any areas whose centroid lies between 0 and 9.5 units in the x-direction using the active coordinate system. This will differ depending on the 'type' of coordinate system you are currently using.
Look up the ASEL command in the help, the answers are there if you can be bothered to look. It will shed all the light you need, read it....
The commands are actually build up very logically.
Area selection of which the location of the X coordinate is between 0 and 9.5.
