Select component in graphic area
cubalibre000
1,070
there is a setting where if I select a component in the graphic area, the same component is highlighted in the Assembly Navigator ?
Thank you...
Hi, I'm sorry, my topic is formuled bad.
How can I edit my post ?
How can I add the quote of an user ?
My real question is :
There is a setting where if I select a sub-assembly component in the graphic area, the same component is highlighted in the Assembly Navigator with expanding the three ?
Thank you...
OK, with the Assembly Navigator pinned open, place your cursor over some 'white space', press MB3, select 'Find Selected Components' (about a 1/3 of the way down the list of items), when the dialog comes up select the Component of interest using your cursor in the graphics area and immediately the 'tree' will expand to show where the selected Component is located.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Hi John,
this is what I'm doing.
The answer to my question is no.
Anyway..thank you..
How is what I described NOT doing what you want?
But if you want an easier option, try adding the 'Find in Navigtor' icon to your 'Selection-bar' and then all that you need to do is select a Component in the graphics area, and then pick this icon. I can't see how we could make it any easier.
John R. Baker, P.E.
Industry Sector
Cypress, CA
I have also added the "Find in Navigator" Selection Bar icon to the Radial Pop-up menu for Select - Shift + Ctrl + MB3 (or other) quick access.
Brad Schuver
Rockwell Collins
Hi John,
I've tried your solution and it's more easier.
Thank you...
