4glennb
Industrial
- Jun 5, 2003
- 9
Hello I have a question regarding the AWS qualification of a flux-wire combination and PWHT. We are having difficulty finding an SAW flux-wire combination to weld a material that our client want's to have a welding procedure that is PWHT. In Section VIII-Div 1 this material does not require PWHT.
Questions are as follows;
-If we qualify the flux-wire combination (in this case F11A6-ECM2-M2-H8) in the PWHT condition do we loose the AWS Classification?
-Under Section IX of the ASME Code if we loose the AWS Classification because we PWHT the welding procedure is there a provision under Section IX that would allow the wire-flux combination to be used in production?
Any help would be greatly appreciated
4glennb
4glennb
