TerryR1
- Apr 27, 2009
- 69
Is anyone aware of any literature on seal friction as applied to high pressure cylinders (~3000psi)?
I'm designing a light load passive heave compensator that uses a pneumatic cylinder. Cylinder stiction looks like it will cause problems, and I want to minimize it.
I found this book one here:
Not sure how useful it may be.
We estimate that it takes 30-50psi to overcome stiction, semi-dependent on cylinder bore size. My math so far shows that stiction is proportional to fluid pressure and to the ratio of seal width to bore diameter.
Input much appreciated!
