Scaling images 2
OnTheJob
20
Hi there
I have a raster image that i want to scale. my problem is the vertical and horizontal scale factors r not the same(get it write horizontally, but vertically its out). Is there a way of making this work? Stretching it doesn't work.
thanx
put the image into a block.
Lothar
ADT 2004
ACAD 2002
what do u mean? I know what the horizontal and vertical length should be. If i get the horizontal right and try and get the vertical to the length its suppose to be the horizontal increases.
you can scale a block with different axes. Make a block, only with your image, calculate the scalevalue and scale it in the properties toolbar.
Or, you work with an image software, like Photoshop, etc...
Lothar
ADT 2004
ACAD 2002
Great tip!
"Everybody is ignorant, only on different subjects." — Will Rogers
