Pekelder
- Mar 31, 2003
- 48
Is it possible to save an assembly, consisting of different parts, as a single part consisting of one solid body with the same outline as the assembly? In Solid Edge this is possible. In this way you can create a welded part from different parts. In higher assemblies you can just load the welded part.
I would like to use this to be able to create simplified representations of assemblies, to speed up loading etc.
Pekelder
Pekelder
