sirbartoo
- Sep 8, 2005
- 53
90% of the people in my company have a rotate/ zoom problem with SW2008/ SW2009. This never happened in SW2006. While in a part or assy (mostly assemblies) if I select a surface and then try and rotate, my assembly rotates, but only in the small command menu box that appears after you select a surface. Kind of like picture in picture on your TV. Is this a known problem? Is there a solution? Thanks in advance.
