VirtualEngineer
- Jan 20, 2005
- 48
I am designing a concrete beam which, due to other constraints, has a width dimension quite a bit larger than may be required due to the applied loading.
Normally in a beam, the minimum amount of steel is limited by the rho = 0.0033 requirement.
I noticed that if I reduced the width of the beam (compression side) and replaced it with, say marshmallow, I meet the rho = 0.0033 and achieve the necessary design strength.
I maintain that by replacing the marshmallow with concrete again, the beam can only get stronger (extra dead weight already allowed for), and my beam is sufficient.
Would anyone out there have a problem with this design, using the effective width of beam?
Regards to all,
JPJ
![[thumbsup2] [thumbsup2] [thumbsup2]](/data/assets/smilies/thumbsup2.gif)
