THERMIK
- Nov 30, 2009
- 13
I have some kind of positioning device that the back and for movement. The current block is positioned in the "0" position with helical spring. Helical spring produce noise and have insufficient range of stiffness.
I would like to replace helical springs with other elastic element (no gas spring).
Can you recommend me any isnt solution e.g. elestomer that is a durable compression and tension or material with quasi Newtonian fluid properties.
Thank you in advance.
//Termik
//Termik
