joeycranston
Chemical
- Oct 9, 2007
- 7
I have the following question for use of a pressure vessel in a code state: For a code-stamped, pressure vessel, if the intent of use of the vessel is at atmospheric pressure, is a relief device mandatory if the code-stamp is removed and documentation generated to say the vessel is considered a non-code vessel? In other words, does the requirement of a relief device apply to a vessel operated or potentially operated (emergency situation) at pressures above 15 psig or does it apply to a vessel constructed to withstand pressure above 15 psig, regardless of the application?
