mfstructural
- Feb 1, 2009
- 230
Hey everyone, curious on getting other people's input on this one. I looked at a wood beam/column system in a basement not too long ago, the beams were visibly sagging a bit and exhibited checking of the wood. I would not characterize the splits as due to tension stresses. Furthermore, the splits were about 1 inch deep on only one side of the beam. I am thinking this can be reinforced by added a steel angle under each bottom corner and either lagging it to the beam or support it on angles at the ends of the beam. the angles supporting the beam angles would be mechanically fastened to the column. I had debated on added a thin steel plate, maybe 1/4" to each side of the beam but I wanted to avoid through bolting through the checking in the beam. I am working with the homeowner to try and reinforce since it may be cheaper than replacing everything....especially since there are pipes and conduit along and near the wood beams. I've included some photos so you have reference.
