lomli
Petroleum
- Apr 27, 2008
- 26
hi,
we have to install a pressure control valve of 10" with its tow block valves and its bypass on a natural gas line of 16",
the control valve will reduce preure from 55 bar to 43 bar, the flow rate i about 200 000 Nm3/hr.
so how to determine the bypass diametter ?
the block valves (to ioslate the PRCV) will be of 10" or 16" (it means the reduction (16"x10")will be befor the block valve or between the control valve and the block valves ) i there any norm or standard ?
thank you
thank you
