Gerry45
- Sep 16, 2002
- 53
Generally it is accepted that if one maintains an adequate ehl film in a rolling brg, the eventual failure will be one of subsurface fatigue due to crack propagation from partical contamination in the steel. Conventional thinking also says that if the ehl is reduced, or contaminents introduced into the lubricant, rolling surface interaction takes place and the failure becomes one of 'surface distress'. Most brgs would be removed from service when either of these two events occur.
It it is logical to assume that even though a brg may be removed because of unacceptable surface damage, some subsurface stressing must have also taken place. However, I have seen many 'abused' rolling brgs in the past,(ie damaged by vibration or small movements whilst idle etc), but not once can I recall seeing one that exhibited both types of failure mode together. Are there good technical reasons for this, or is it simply that the brgs weren't left in service long enough to allow time for both types of damage to develop ?
The reason I ask is this. I have a slewing ring application where 'surface distress' (due to the slow and occasional nature of the rotation) is normal and tolerated. (It is not noise or smoothness sensitive, but because of the operating conditions there is no alternative but to accept gradual with wear and deterioration of the raceways.) However, in the future, the frequency of slewing movements is likely to increase dramatically on my machines so I am wondering if I can expect to see not only surface damage, but some subsurface fatigue developing too after a period of time. My concern is that if this happened this could take the deterioration beyond the norm and up to unacceptable levels !
Does anyone have any thoughts or experience in this field ? My own feelings are this. Although increasing frequency of angular oscillation will contribute to more sub-surface stress cycling, it will also increases the surface wear rate. This may have the effect of wiping out the fatigue. For example, I can imagine that if I had the potential to create a 'false brinell' pits of say 10% of the ball diameter, this would be far deeper than the initial maximum shear stress point from where fatigue would normally originate. So the progression of the wear would mean that the max shear stress cycling point is constantly being moved lower down to fresh material and the onset of fatigue is delayed. I look forward to your comments.
Gerry
Gerry
