BillyShope
Automotive
- Sep 5, 2003
- 263
Section 8.2 of Race Car Vehicle Dynamics describes the constrained testing which was done before the development of the sophisticated fixturing now common to the major manufacturers. The car was tethered to a much heavier vehicle and observations and measurements were made as the two moved...side-by-side...at essentially walking speed and the car was steered away from the heavier vehicle.
For most race car developers, both the sophisticated fixturing and the constrained testing might be impractical. But, it recently occurred to me that some valuable information can be gained within the confines of a small shop with a very simple test setup.
The motion involved in the constrained testing is necessary to develop the tire slip angles, but, if all that is needed is information on the roll couple distribution, the motion is not necessary. Suppose that a horizontal chain is attached to the right side of an oval track car, exactly at the midpoint of the wheelbase and at a height equal to, or greater than, that of the center of gravity. It would be necessary, of course, to fully scale the car before this test begins. Now, with the scales removed, jack up the left side of the car, shorten the chain, and then ease the left side tires down onto wheel scales. After reading the scales and then calculating the right side loads, it is possible to determine roll couple distribution.
By attaching the chain at two different heights, it would also be possible to determine the roll axis height at the wheelbase midpoint.
