BigH
Geotechnical
- Dec 1, 2002
- 6,012
Dear All:
Just wanted to see if anyone has any opinions on the topic. ACI/AASHTO, etc. typically use 2 cylinder breaks at 28-d in order to show compliance with the specified strengths subject to three moving averages being greater than the specified strength and no single cyliner less than 3.5 MPa (500 psi) below the specified strength. This is based on no more than 1 in 20 being below the specified strength and is a function of the standard deviation of the test results.
In Asia, it is customary to break three cylinders (or cubes - but now generally cylinders) rather than 2 cylinders. It is my contention that the average of the three cylinders is "closer" to the true value of the set than the average of 2 cylinders. Would this change the definition of compliance? Say, that the moving average be no less than 0.5 MPa (100 psi) less than the specified average and no single test value less than, say, 4 MPa below the average?
On our job we are breaking three but still using the ACI definition of compliance.
Any thoughts? Ron??
Cheers to all - hoping that we are all still "above water".
Any thoughts? Ron??
