Question about Independency Principle 1
pmarc
3,227
Imagine that fig. 2-7 from Y14.5-2009 shows a pin instead of the rectangular block, and the flatness callout has been replaced by straightness FCF. Everything else stays the same (of course the diameter symbol is added to 10.7-10.8 dimension).
Knowing this, what is the minimum possible diameter of a perfect cylindrical boundary that the pin would never violate?
Thanks.
Para. 3.5.
LOCAL SIZE OF AN EXTRACTED CYLINDER, LOCAL DIAMETER OF AN EXTRACTED CYLINDER
distance between two opposite points on the feature, where
— the connection line between the points includes the associated circle centre; and
— the cross-sections are perpendicular to the axis of the associated cylinder obtained from the extracted surface
IOW, is a local diameter one consistent number or can a local diameter vary as we rotate around the circle?
Well, the lower picture shows two local diameters, so I would not interpret it as one consistent number in a single cross-section.
Thanks -- that helps a lot. Unlike ASME's definition, this one states that "the connection line between the points includes the associated circle centre."
John-Paul Belanger
Geometric Learning Systems
That is right. Of course there are other issues with this definition, but if we are solely talking about the connection line between two points, I think there is way less ambiguity in ISO in comparison to what has been defined in ASME.
