AMontembeault
- May 13, 2014
- 31
Hello, I was wondering if some of you all might be able to clairify or perhaps share some "best practices" with respect to calling out quantities on engineering drawings when it comes to features (lets say holes) in a pattern.
Here is the confusion: In the GD+T standard, sections 1.9.5 and 1.9.5.1, a numeric callout of quantity "May" be used to indicate the number of features to which that dimension is applied. My interpretation of that is if, for example, I had a square 4-hole pattern (lets say 100 mm spacing in both the horizontal and vertical, I could either dimension it as 100 x 100 (basic of course) or 2x 100 x 2x 100 (again, basic), and either is technically correct.
But suppose I had multiple patterns with holes of various sizes laying on the same line? What then? What should I do if I have a number of holes of differing sizes which I'd still like to control as a pattern?
(See attached crude and hastily drawn sketch for clarification of what I'm asking)
