1
- #1
kme
- Jan 16, 2003
- 10
Any California engineers out there? I was wondering if someone could describe to me the process a structural engineer goes through to obtain a building permit in California. It is my understanding that the Authority having Jurisdiction will complete an independant technical review of the drawings and the result of this review largely determines whether the permit will be issued. It is also my understanding the Authority having Jurisdiction also requires that field review be performed by an independant party. Are these provision across the board for all projects or are the specific to certain types of buildings (i.e. size or type of construction)? What are the pros and cons of this system?
The reason for my query: Here in Canada there is a considerable push towards licensing of Specialty Engineers. In fact, in British Columbia, all structural engineers will have to pass the British I.Struct.E. technical exams plus a couple of other exams in order to practice structural engineering. It is my opinion that this is the wrong approach and that in fact, the problem with the our existing system is that quality control is a very passive (i.e. the code of conduct simply states that all work shall be checked by another engineer) and left entirely to the discretion of the company or engineer performing the work.
I see the Californian process as an active process whereby one has to have an INDEPENDANT review prior to construction. This is the bottom line: forget about qualifications of individual engineers, if your design is not up to snuff, you can't build it. If your behavior is viewed as unprofessional or negligent, it is quite likely you are going to get reported when your project is reviewed. If you produce poor quality designs that take to long to get through permit application stage, you are probably going to lose clients.
Seems straight forward to me.
N.B. It is important to note that Canadian engineers are licensed by a self governed association as opposed to a government body.
