okie
- Feb 7, 2003
- 1
My question concerns the best configuation to use when controlling a centrifigal pump by way of recycle. Assume that all the economics have been run and it has been decided that recycle control is the option that will be used for pump control i.e. VFD is not an option. In our specific case we are controlling level in a vessel and have a centrifigal pump moving the liquid. The pressure that the pump must overcome is not constant and may range from 10-100 psi. We actually have several teams with very similar situations and as a company we would like for the designs to be as close to one another as practical. As luck would have it, each team has come up with a slightly different control scheme which I list below. My question is "Since this is obviously not the first time that this has been done, is there a generally agreed upon "best way" to configure such a system?" Some of the different proposed configurations are....
1) Control Pump discharge pressure with a PCV on the pump discharge and control level with the recycle valve. The recycle valve to be located upstream of the PCV.
2) Control Pump discharge pressure with the recycle valve and control level with a LCV on the pump discharge. The recycle valve to be located upstream of the LCV. (Basically oposite of option 1)
3) Same as opton 1 but have the recycle (or LCV) located downstream of the PCV.
4) Level control with LCV on pump discharge and minimum bypass flow control with a FCV located upstream of the LCV. Flow meter located upstream of both LCV & FCV.
Clear as mud huh?
Thanks in advance!
Clear as mud huh?
Thanks in advance!
